I want to use LSM6DSV as A+G Sensor on my i.MX8MQ Custom board and the Linux version is 6.1.36.
I found that it is not supported for LSM6DSV. It seems to need to wait for Linux 6.2 and the driver will be update.
Is it possible using this sensor at Linux 6.1? If it is possible, how can I do?
Thanks & Regards,
Derek Lin
已解决! 转到解答。
You can port it:
https://github.com/torvalds/linux/blob/master/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx_core.c
You can port it:
