Hello NXP Team,
The qualified LPDDR part for IMX8M PLUS processor is obsolete.
Can you please share an other 4GB LPDDR part which are compatible with IMX8M PLUS processor.
Waiting for your reply.
Hello, I hope you are doing well.
We do not have a list of recommended part numbers.
I suggest you select a LPDDR memory according to the hardware developer's guide and just to be safe on your design I would suggest to re-calibrate and run the DDR stress tool:
i.MX 8M Family DDR Tool Release
This would help on getting configuration for your new DDR.
Best regards.
Hello @JorgeCas
Can we use the MT53E1G32D2FW-046 WT:B LPDDR part with IMX8M PLUS processor.
I do not have access to the hole information of selected part number, such as datasheet but, from general information on internet seems it should work ok. I suggest double check with hardware developer's guide.
Best regards.
Hello @JorgeCas
Can we use the samsung K4FBE3D4HB-KHCL LPDDR part with IMX8M PLUS processor.
Hello @JyotiVaishnav , apologies for the delay.
I checked the general features about the mentioned part number and also seems ok to be used on your design.
Best regards.
Awaiting for you reply.
