LPDDR4 Calibration Fail on IMX8MP
prashanthk_k
I am using 4GB LPDDR4 (MT53E1G32D2FW-046 IT:C) on iMX8MP custom board.
While performing DDR calibration with MSCALE tool, I am facing below issue.
Download is complete
Waiting for the target board boot...
===================hardware_init=====================
********Found PMIC PCA9450**********
hardware_init exit
MX8 DDR Stress Test V3.30
Built on Nov 24 2021 13:52:12
Waiting for board configuration from PC-end...
--Set up the MMU and enable I and D cache--
- This is the Cortex-A53 core
- Check if I cache is enabled
- Enabling I cache since it was disabled
- Push base address of TTB to TTBR0_EL3
- Config TCR_EL3
- Config MAIR_EL3
- Enable MMU
- Data Cache has been enabled
- Check system memory register, only for debug
- VMCR Check:
- ttbr0_el3: 0x97d000
- tcr_el3: 0x2051c
- mair_el3: 0x774400
- sctlr_el3: 0xc01815
- id_aa64mmfr0_el1: 0x1122
- MMU and cache setup complete
ARM clock(CA53) rate: 1800MHz
DDR Clock: 2000MHz
DDR configuration
DDR type is LPDDR4
Data width: 32, bank num: 8
Row size: 17, col size: 10
One chip select is used
Number of DDR controllers used on the SoC: 1
Density per chip select: 4096MB
Density per controller is: 4096MB
Total density detected on the board is: 4096MB
MX8M-plus: Cortex-A53 is found
============ Step 1: DDRPHY Training... ============
---DDR 1D-Training @2000Mhz...
[Process] End of CA training
[Process] End of initialization
[Process] End of read enable training
[Process] End of fine write leveling
[Process] End of read DQ deskew training
[Process] End of MPR read delay center optimization
[Process] End of Write Leveling coarse delay
[Process] End of write delay center optimization
[Process] End of read delay center optimization
[Process] End of max read latency training
[Result] PASS
---DDR 1D-Training @200Mhz...
[Result] PASS
---DDR 1D-Training @50Mhz...
[Result] PASS
---DDR 2D-Training @2000Mhz...
[Process] End of 2D write delay/voltage center optimization
[Process] End of 2D read delay/voltage center optimization
[Result] PASS
============ Step 2: DDR memory accessing... ============
Verifying DDR frequency [email protected] of failure: 0x0000000040080000
Data read was: 0x0000000040000010
But pattern was: 0x0000000040000000
Failed
Please modify DDRC/DFI parameters!!!
NXP iMX/MSCALE tool Version - 3.31
iMX8MP RPA Tool version - v9
The DDR configuration updated on RPA tool as below for reference.
Please someone can help how to fix 'Please modify DDRC/DFI parameters' for LPDDR4 on IMX8MPLUS board.
Prashanth K
pengyong_zhang
Hi, @prashanthk_k
 i will support your this problem on your case https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, So please close this ticket, and  see the reply on case 00626079.
B.R
bozsahin
Hello, I’m getting the same fail. I'm using THE MT53E1G32D2FW . Could you please share how you resolved it? I’d appreciate your help.
Data read was: 0x0000000040000020
Failed
pengyong_zhang
Hi, @prashanthk_k
B.R
Zhirong_Yang
Hi @pengyong_zhang
I am facing the same failure on DDR calibration, and I can not access below link https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, is there any way to view this link?
Zhirong_Yang
%3CLINGO-SUB%20id%3D%22lingo-sub-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPDDR4%20Calibration%20Fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20using%204GB%20LPDDR4%20(MT53E1G32D2FW-046%20IT%3AC)%20on%20iMX8MP%20custom%20board.%3C%2FP%3E%3CP%3EWhile%20performing%20DDR%20calibration%20with%20MSCALE%20tool%2C%20I%20am%20facing%20below%20issue.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3EDownload%20is%20complete%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EWaiting%20for%20the%20target%20board%20boot...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E********Found%20PMIC%20PCA9450**********%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Ehardware_init%20exit%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EMX8%20DDR%20Stress%20Test%20V3.30%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EBuilt%20on%20Nov%2024%202021%2013%3A52%3A12%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EWaiting%20for%20board%20configuration%20from%20PC-end...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E--Set%20up%20the%20MMU%20and%20enable%20I%20and%20D%20cache--%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20This%20is%20the%20Cortex-A53%20core%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Check%20if%20I%20cache%20is%20enabled%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Enabling%20I%20cache%20since%20it%20was%20disabled%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Push%20base%20address%20of%20TTB%20to%20TTBR0_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Config%20TCR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Config%20MAIR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Enable%20MMU%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Data%20Cache%20has%20been%20enabled%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Check%20system%20memory%20register%2C%20only%20for%20debug%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20VMCR%20Check%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20ttbr0_el3%3A%200x97d000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20tcr_el3%3A%200x2051c%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20mair_el3%3A%200x774400%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20sctlr_el3%3A%200xc01815%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20id_aa64mmfr0_el1%3A%200x1122%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20MMU%20and%20cache%20setup%20complete%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EARM%20clock(CA53)%20rate%3A%201800MHz%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%20Clock%3A%202000MHz%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%20configuration%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%20type%20is%20LPDDR4%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EData%20width%3A%2032%2C%20bank%20num%3A%208%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ERow%20size%3A%2017%2C%20col%20size%3A%2010%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EOne%20chip%20select%20is%20used%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ENumber%20of%20DDR%20controllers%20used%20on%20the%20SoC%3A%201%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDensity%20per%20chip%20select%3A%204096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDensity%20per%20controller%20is%3A%204096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ETotal%20density%20detected%20on%20the%20board%20is%3A%204096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMX8M-plus%3A%20Cortex-A53%20is%20found%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20Step%201%3A%20DDRPHY%20Training...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-Training%20%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20CA%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20initialization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20enable%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20fine%20write%20leveling%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20DQ%20deskew%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20MPR%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20Write%20Leveling%20coarse%20delay%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20write%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20max%20read%20latency%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BResult%5D%20PASS%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-Training%20%40200Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20CA%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20initialization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20enable%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20fine%20write%20leveling%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20MPR%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20Write%20Leveling%20coarse%20delay%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20write%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20max%20read%20latency%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BResult%5D%20PASS%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-Training%20%4050Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20CA%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20initialization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20enable%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20fine%20write%20leveling%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20MPR%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20Write%20Leveling%20coarse%20delay%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20write%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20read%20delay%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20max%20read%20latency%20training%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BResult%5D%20PASS%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%202D-Training%20%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%20initialization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%202D%20write%20delay%2Fvoltage%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%202D%20write%20delay%2Fvoltage%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%202D%20read%20delay%2Fvoltage%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BProcess%5D%20End%20of%202D%20read%20delay%2Fvoltage%20center%20optimization%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5BResult%5D%20PASS%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20Step%202%3A%20DDR%20memory%20accessing...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EVerifying%20DDR%20frequency%20point0%402000MHz......Address%20of%20failure%3A%200x0000000040080000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EData%20read%20was%3A%200x0000000040000010%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EBut%20pattern%20was%3A%200x0000000040000000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EFailed%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPlease%20modify%20DDRC%2FDFI%20parameters!!!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ENXP%20iMX%2FMSCALE%20tool%20Version%20-%203.31%3C%2FP%3E%3CP%3EiMX8MP%20RPA%20Tool%20version%20-%20v9%3C%2FP%3E%3CP%3EThe%20DDR%20configuration%20updated%20on%20RPA%20tool%20as%20below%20for%20reference.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F283871i54B1E25B9CEF0A62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rpa_tool.png%22%20alt%3D%22rpa_tool.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPlease%20someone%20can%20help%20how%20to%20fix%20'%3CSTRONG%3EPlease%20modify%20DDRC%2FDFI%20parameters%3C%2FSTRONG%3E'%26nbsp%3Bfor%20LPDDR4%20on%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3EIMX8MPLUS%3C%2FA%3E%26nbsp%3Bboard.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EPrashanth%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPDDR4%20Calibration%20Fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20am%20facing%20the%20same%20failure%20on%20DDR%20calibration%2C%20and%20I%20can%20not%20access%20below%20link%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%3C%2FA%3E%3CSPAN%3E%26nbsp%3Bis%20there%20any%20way%20to%20view%20this%20link%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPDDR4%20Calibration%20Fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20facing%20the%20same%20failure%20on%20DDR%20calibration%2C%20and%20I%20can%20not%20access%20below%20link%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%3C%2FA%3E%26nbsp%3Bis%20there%20any%20way%20to%20view%20this%20link%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPDDR4%20Calibration%20Fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%E2%80%99m%20getting%20the%20same%20fail.%20I'm%20using%20THE%20MT53E1G32D2FW%20.%20Could%20you%20please%20share%20how%20you%20resolved%20it%3F%20I%E2%80%99d%20appreciate%20your%20help.%26nbsp%3B%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20Step%202%3A%20DDR%20memory%20accessing...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EVerifying%20DDR%20frequency%20point0%402000MHz......Address%20of%20failure%3A%200x0000000040080000%3CBR%20%2F%3EData%20read%20was%3A%200x0000000040000020%3CBR%20%2F%3EBut%20pattern%20was%3A%200x0000000040000000%3CBR%20%2F%3EFailed%3CBR%20%2F%3EPlease%20modify%20DDRC%2FDFI%20parameters!!!%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPDDR4%20Calibration%20Fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234740%22%20target%3D%22_blank%22%3E%40prashanthk_k%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3Bi%20will%20support%20your%20this%20problem%20on%20your%20case%20%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%3C%2FA%3E%26nbsp%3BSo%20please%20close%20this%20ticket%2C%20and%26nbsp%3B%20see%20the%20reply%20on%20case%26nbsp%3B%3CSPAN%3E00626079.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
