LMT101ENMFWD-ACD LCD 10.1'' HDMI with i.MX 8M Plus EVK Board
eslam
i am using LMT101ENMFWD-ACD LCD 10.1" with the i.MX 8M Plus EVK Board through HDMI connection.
i have flashed the i.MX 8M Plus EVK with LF_v6.12.34-2.1.0_images_IMX8MPEVK.zip image
When the board boots up, the default resolution causes the content on the display to be squished.
i tried to update the weston.ini file but no impact happens.
could you please tell me step by step how to update the resolution?
thanks
Eslam
AldoG
You may refer to the following community document if you are using HDMI port it is pretty straight forward:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-change-the-HDMI-pixel-clock-and-c...
Hope this helps,
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2181198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELMT101ENMFWD-ACD%20LCD%2010.1''%20HDMI%20with%20i.MX%208M%20Plus%20EVK%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3Ei%20am%20using%26nbsp%3B%3CSTRONG%3ELMT101ENMFWD-ACD%20LCD%2010.1%22%3C%2FSTRONG%3E%20with%20the%26nbsp%3B%3CSTRONG%3Ei.MX%208M%20Plus%20EVK%3C%2FSTRONG%3E%20Board%20through%20HDMI%20connection.%26nbsp%3B%3C%2FP%3E%3CP%3Ei%20have%20flashed%20the%26nbsp%3B%3CSTRONG%3Ei.MX%208M%20Plus%20EVK%20%3C%2FSTRONG%3Ewith%20%3CSTRONG%3ELF_v6.12.34-2.1.0_images_IMX8MPEVK.zip%3C%2FSTRONG%3E%20image%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EWhen%20the%20board%20boots%20up%2C%20the%20default%20resolution%20causes%20the%20content%20on%20the%20display%20to%20be%20squished.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ei%20tried%20to%20update%20the%26nbsp%3B%3CSTRONG%3Eweston.ini%20%3C%2FSTRONG%3Efile%20but%20no%20impact%20happens.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Ecould%20you%20please%20tell%20me%20step%20by%20step%20how%20to%20update%20the%20resolution%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Ethanks%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEslam%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2181198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LMT101ENMFWD-ACD%20LCD%2010.1''%20HDMI%20with%20i.MX%208M%20Plus%20EVK%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20may%20refer%20to%20the%20following%20community%20document%20if%20you%20are%20using%20HDMI%20port%20it%20is%20pretty%20straight%20forward%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-change-the-HDMI-pixel-clock-and-change-the-panel%2Fta-p%2F2131344%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-change-the-HDMI-pixel-clock-and-change-the-panel%2Fta-p%2F2131344%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EHope%20this%20helps%2C%3CBR%20%2F%3EBest%20regards%2FSaludos%2C%3CBR%20%2F%3EAldo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
