Hi team
our customer is LGE-HA (Home Appliance)
BSP : L4.14.98
CPU: i.mx6dq_sabresd
customer enable display feature with adding some kernel configuration
They do not backend server. LGE use FB with QT app.
They observed memory increased after adding FB related configuration. increased memory size is about 60MB without any QT application run.
It seems... only kernel configuration cause 60MB memory increasion
This display added project is based on previous NO display project.
So, i attached two configuration files, one is no display and another is enablement FB related.
rrc_defconfig_20201005_FB_Enablement.txt : for display feature
cgw_defconfig_20101005.txt : No Display project.
Could you please check these defconfig file and guide unnecessary configuration which could be removed from default FB operation.
Solved! Go to Solution.
I should close this ticket. moved other space.
BRs
jessie
