LCD flickering with IMX6ULL
joeyTian
Env: NXP IMX6ULL + LVGL 7.11.0
issue: The LCD display shows with millisecond flickering once the SD card insert or play the mp3 on the board, I assume the system interrupt triggers this issue.
How should I avoid this, is there anyone have the experience or suggestion for this?
Thanks a lot in advance.
jimmychan
You should do more tests on your board to narrow down the issue first.
joeyTian
Kind of, it may be the hardware issue, still investigating.
Thanks anyway.
