I am using i.MX6 Dual lite board.I want to know where I can find the 24-bit parallel interfacing lcd driver.I am using ipu0.
Basically I want to know where can i find the parallel interface lcd Driver?
Can anyone plzz help me with this issue.
Thanks in advance.
Solved! Go to Solution.
hi you may refer to "drivers/video/mxc/mxcfb_seiko_wvga.c", and "arch/arm/mach-mx6/board-mx6sl_arm2.c" includes the configuration.
