LCD display on imx6, linux 5.4
3,955 次查看
woutervh
I want to add a LCD to a custom imx6 board.
Before, there was the file mxc_lcdif.c, which had the fsl,lcd compatible. Then you had a node in the devicetree, describing which ipu/di/...
However, this seems to be removed/changed in kernel 5.4?
How do I add an lcd display the proper way now?
标签 (4)
5 回复数
3,863 次查看
joanxie
you can refer to the link as below, how to change the dts file for lcd
https://community.nxp.com/message/483756
3,863 次查看
woutervh
Yes, but that is my problem. This way is no longer working on 5.4....
It was working fine on 4.19 (also here)
3,863 次查看
joanxie
I know what you mean, I have built 5.4.3-1.0.0, and searched mxc_lcdif.c, it seems 5.4.3 has removed this file
3,863 次查看
woutervh
Exactly. And to my understanding, that's a mistake someone made in a merge somewhere. I've just put it back, and lcd works perfectly again as it did before...
3,863 次查看
joanxie
thanks for your sharing, I don't know who is the owner of this, but your test is very useful for other customers
