LAY-31399_C.brd in ASCII (alg)
Search instead for
chads108
Is it possible to get this board, LAY-31399_C.brd, as an ASCII file that I can import to Altium please?  It would be something like LAY-31399_C.brd.alg.
Thank you.
Chad
chads108
Your policy is not followed consistently then.  Several different posts show someone at NXP providing these files.
I will look elsewhere for help.
chads108
It appears that NXP has made the ASCII export file for Altium available in the past.  I can search through this site and find several examples of where that was done.  Has your policy changed?  Is it just this board you will not convert?
gusarambula
Hello Chad,
The policy is to provide only the files as available on the Design Files bundles. However, there may be users in the forums with an Allegro license that have been willing to help exporting the design in this format.
My apologies for the inconvenience.
gusarambula
Hello Chad,
Only the regular files in Allegro format are provided as part of the Design Files bundle for each board.
