L5.1.1_2.1.0 mfg firmware u-boot and kernel
1,346 次查看
xianyoju
how to build the BSP L5.1.1_2.1.0 mfg firmware?
i can not found the mfg config in u-boot and kernel in the newest BSP!!!!
1,123 次查看
BiyongSUN
You can ask a software engineer to help you review the uboot source code by searching "is_boot_from_usb".
From the 3.10 BSP, the uboot is shared with mfg tool.
uboot-imx\common\main
#ifdef is_boot_from_usb
if (is_boot_from_usb()) {
  printf("Boot from USB for mfgtools\n");
  bootdelay = 0;
  set_default_env("Use default environment for mfgtools\n");
} else {
  printf("Normal Boot\n");
#endif
4 回复数
1,123 次查看
SergioSolis
Hello XianYo,
Can you please tell me which evaluation board are you using?... did you download both the bsp and mfg tools?.
Can you be more specific on what you can't do?
1,123 次查看
xianyoju
our custom board
in the old bsp
we must rebuild the mfg uboot and kernel firmware
but thre newest bsp do not have the mfg config
1,124 次查看
BiyongSUN
  bootdelay = 0;
} else {
#endif
1,123 次查看
xianyoju
got it. thanks!
