In the release note of L4.14.98 2.3.0, it said supports i.MX 8QuadXPlus C0 chip.
May we know how to check the i.MX8X chip is C0 or not? By part number?
解決済! 解決策の投稿を見る。
To distinguish between i.MX 8X B0 and i.MX8X C0 parts, users can check the
last letter of the part number, which indicates the silicon reversion. For
example, MiMX8QX6AVLFZAB indicates that it is i.MX 8X B0 part, while
MiMX8QX6AVLFZAC indicating that it is i.MX 8X C0 part.
yocto building is based on board, you can find board revision B0 or C0 on your imx8qxp board.
Thank you for your reply,
If customer build their own board.
How to make sure the i.MX8X IC is C0?
