Keys creation with CAAM and OP-TEE
1,539件の閲覧回数
M_J
We want to perform authentication with CAAM and OP-TEE without revealing private key (just keep it in CAAM). We are using i.MX8MM and branch 5.4.70_2.3.0 with corresponding kernel and u-boot.
This is typical scenario:
  • generate public key to corresponding private key (without revealing it at any step, the best is to use secure world) and send it to backend
  • pass data to TA (trusted application), decrypt data encrypted by public key, solve challenge, encrypt it and send back to backend
We have troubles in understanding, some details:
  • Is the proposed scenario possible? We considered options like creating black key blobs (AN12838) in OP-TEE or using manufacturing protection (AN13222) - are we on the right track?
  • We have seen a repository https://source.codeaurora.org/external/imxsupport/imx_sec_apps/, however it is hard to figure out whether our idea is possible or not. Do you have more detailed examples or documentation?
  • Is it possible to simultaneously use CAAM from OP-TEE and from kernel?
  • We have seen support mostly for 4.14, is 5.4 supported as well?
We would appreciate any feedback and/or suggestions. It would be extremely helpful to receive relevant documentation and/or examples.
Moreover we would like to have access to document https://community.nxp.com/docs/DOC-343388, however from my account access is denied. We have signed NDA with NXP, could you grant me access to mentioned document?
2 返答(返信)
1,514件の閲覧回数
M_J
Hi @jimmychan
I have created ticket as you requested.
Is it enough to proceed with the issue?
1,523件の閲覧回数
jimmychan
We need to verify your NDA and then send you the information. It is better to create a ticket for this.
https://support.nxp.com/s/
Thanks.
