Kernel booting hangs after swupdate.service
2,402件の閲覧回数
meetalipatel
Hi Team,
I am trying to integrate meta-swupdate to Yocto Linux BSP Linux 6.1.22_2.0.0​ for a custom board based on i.MX6ULL processor. I followed this document for porting. I am using the meta-swupdate layer from here
When I build and run the generated image on the custom board, I have observed that the kernel booting hangs after swupdate.service starts. I am attaching the booting logs for reference. I have also attached the defconfig file that I am using for SWUpdate.
Any help would be appreciated!
Thanks in advance.
Meetali Patel
2,345件の閲覧回数
Bio_TICFSL
You nee to update the https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Porting-swupdate-based-on-AN13872/ta-p/1...
you can put your question there.
