Jump to application from IVT failed on i.MX RT1176 with SDK2.8
889 次查看
scarletlee
I can jump to application layer form IVT layer on i.MX RT1176 with SDK 2.10 succeed.
But I always failed with SDK 2.8, so could you lead me find the way?
880 次查看
scarletlee
I found the mistake in my code, it work with SDK 2.8 after corrected.
Could you close this stupid issue?
Thanks.
