Jtag debugger for i.MX 6ULL famile processor
1,233 次查看
deljo_davis
I using MCIMX6Y2CVM08AB. Can suggest Jtag Debuggers suitable for this product.
1,175 次查看
ceggers1
Selecting a JTAG debugger depends mainly on your needs and budget. Everything between 5$ (FTDI based) and 5000$ (Lauterbach Power Debug Pro) should be possible.
  • If you only want program the flash memory, you can also use the i.MX ROM bootloader and connect via USB (for free).
  • For development of Linux applications, you can do most tasks purely with software debuggers (e.g. gdbserver).
  • For working on bootloaders, real time operating system or the Linux kernel I personally prefer the Lauterbach solution. But be prepared to invest some time to learn how to use this system. It's very powerful but not always intuitive.
regards
Christian
1,176 次查看
ceggers1
regards
Christian
