Issues with EGL in iMX8MP
santhanakumar
I followed the below instructions from NXP and ported Debian to our board:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Build-Ubuntu-For-i-MX8-Series-Platform/t...
The link describes steps to port Ubuntu. I could adapt the instructions to port Debian to our board.
Our board is using iMX8MP SoC.
I used latest NXP Yocto, Hardknott SDK for porting Debian.
I could able to port successfully debian to our board and run most of the applications available from Yocto in Debian.
These applications include gstreamer, glmark2-es2, QT, wayland etc.
The ported Debian is able to use VPU and GPU features of SoC.
I could able to play 60fps videos using VPU and gstreamer.
Also able to run GPU demos using glmark2-es2.
Then we tried to run our customer Application.
Customer application uses EGL to perform some Graphics.
But application failed to access EGL with the below error:
[ 1] Failed EGL API GetProcAddress: eglLockSurfaceKHR !
[ 2] Failed EGL API GetProcAddress: eglUnlockSurfaceKHR !
[ 3] Failed EGL API GetProcAddress: eglBindWaylandDisplayWL !
[ 4] Failed EGL API GetProcAddress: eglUnbindWaylandDisplayWL !
[ 5] Failed EGL API GetProcAddress: eglQueryWaylandBufferWL !
[ 6] Failed EGL API GetProcAddress: eglUpdateWaylandBufferWL !
[ 7] Failed EGL API GetProcAddress: eglSetDamageRegionKHR !
[ 8] Failed EGL API GetProcAddress: eglSwapBuffersWithDamageEXT !
[ 9] Failed EGL API GetProcAddress: eglQueryDmaBufFormatsEXT !
[ 10] Failed EGL API GetProcAddress: eglQueryDmaBufModifiersEXT !
[ 11] Failed EGL API GetProcAddress: eglPatchID !
[ 12] Failed ES_Common API GetProcAddress: forward_glActiveTexture !
[ 13] Failed ES_Common API GetProcAddress: forward_glBindBuffer !
[ 14] Failed ES_Common API GetProcAddress: forward_glBindTexture !
[ 15] Failed ES_Common API GetProcAddress: forward_glBlendFunc !
[ 16] Failed ES_Common API GetProcAddress: forward_glBufferData !
[ 17] Failed ES_Common API GetProcAddress: forward_glBufferSubData !
[ 18] Failed ES_Common API GetProcAddress: forward_glClear !
[ 19] Failed ES_Common API GetProcAddress: forward_glClearColor !
[ 20] Failed ES_Common API GetProcAddress: forward_glClearDepthf !
[ 21] Failed ES_Common API GetProcAddress: forward_glClearStencil !
[ 22] Failed ES_Common API GetProcAddress: forward_glColorMask !
[ 23] Failed ES_Common API GetProcAddress: forward_glCompressedTexImage2D !
[ 24] Failed ES_Common API GetProcAddress: forward_glCompressedTexSubImage2D !
[ 25] Failed ES_Common API GetProcAddress: forward_glCopyTexImage2D !
[ 26] Failed ES_Common API GetProcAddress: forward_glCopyTexSubImage2D !
[ 27] Failed ES_Common API GetProcAddress: forward_glCullFace !
[ 28] Failed ES_Common API GetProcAddress: forward_glDeleteBuffers !
[ 29] Failed ES_Common API GetProcAddress: forward_glDeleteTextures !
[ 30] Failed ES_Common API GetProcAddress: forward_glDepthFunc !
[ 31] Failed ES_Common API GetProcAddress: forward_glDepthMask !
[ 32] Failed ES_Common API GetProcAddress: forward_glDepthRangef !
[ 33] Failed ES_Common API GetProcAddress: forward_glDisable !
[ 34] Failed ES_Common API GetProcAddress: forward_glDrawArrays !
[ 35] Failed ES_Common API GetProcAddress: forward_glDrawElements !
[ 36] Failed ES_Common API GetProcAddress: forward_glEnable !
[ 37] Failed ES_Common API GetProcAddress: forward_glFinish !
[ 38] Failed ES_Common API GetProcAddress: forward_glFlush !
[ 39] Failed ES_Common API GetProcAddress: forward_glFrontFace !
[ 40] Failed ES_Common API GetProcAddress: forward_glGenBuffers !
[ 41] Failed ES_Common API GetProcAddress: forward_glGenTextures !
[ 42] Failed ES_Common API GetProcAddress: forward_glGetBooleanv !
[ 43] Failed ES_Common API GetProcAddress: forward_glGetBufferParameteriv !
[ 44] Failed ES_Common API GetProcAddress: forward_glGetError !
[ 45] Failed ES_Common API GetProcAddress: forward_glGetFloatv !
[ 46] Failed ES_Common API GetProcAddress: forward_glGetIntegerv !
[ 47] Failed ES_Common API GetProcAddress: forward_glGetPointerv !
[ 48] Failed ES_Common API GetProcAddress: forward_glGetString !
[ 49] Failed ES_Common API GetProcAddress: forward_glGetTexParameterfv !
[ 50] Failed ES_Common API GetProcAddress: forward_glGetTexParameteriv !
[ 51] Failed ES_Common API GetProcAddress: forward_glHint !
[ 52] Failed ES_Common API GetProcAddress: forward_glIsBuffer !
[ 53] Failed ES_Common API GetProcAddress: forward_glIsEnabled !
[ 54] Failed ES_Common API GetProcAddress: forward_glIsTexture !
[ 55] Failed ES_Common API GetProcAddress: forward_glLineWidth !
[ 56] Failed ES_Common API GetProcAddress: forward_glPixelStorei !
[ 57] Failed ES_Common API GetProcAddress: forward_glPolygonOffset !
[ 58] Failed ES_Common API GetProcAddress: forward_glReadPixels !
[ 59] Failed ES_Common API GetProcAddress: forward_glSampleCoverage !
[ 60] Failed ES_Common API GetProcAddress: forward_glScissor !
[ 61] Failed ES_Common API GetProcAddress: forward_glStencilFunc !
[ 62] Failed ES_Common API GetProcAddress: forward_glStencilMask !
[ 63] Failed ES_Common API GetProcAddress: forward_glStencilOp !
[ 64] Failed ES_Common API GetProcAddress: forward_glTexImage2D !
[ 65] Failed ES_Common API GetProcAddress: forward_glTexParameterf !
[ 66] Failed ES_Common API GetProcAddress: forward_glTexParameterfv !
[ 67] Failed ES_Common API GetProcAddress: forward_glTexParameteri !
[ 68] Failed ES_Common API GetProcAddress: forward_glTexParameteriv !
[ 69] Failed ES_Common API GetProcAddress: forward_glTexSubImage2D !
[ 70] Failed ES_Common API GetProcAddress: forward_glViewport !
[ 71] Failed ES_Common API GetProcAddress: forward_glMapBufferOES !
[ 72] Failed ES_Common API GetProcAddress: forward_glUnmapBufferOES !
[ 73] Failed ES_Common API GetProcAddress: forward_glEGLImageTargetTexture2DOES !
[ 74] Failed ES_Common API GetProcAddress: forward_glEGLImageTargetRenderbufferStorageOES !
[ 75] Failed ES_Common API GetProcAddress: forward_glMultiDrawArraysEXT !
[ 76] Failed ES_Common API GetProcAddress: forward_glMultiDrawElementsEXT !
[ 77] Failed ES_Common API GetProcAddress: forward_glTexDirectVIV !
[ 78] Failed ES_Common API GetProcAddress: forward_glTexDirectInvalidateVIV !
[ 79] Failed ES_Common API GetProcAddress: forward_glTexDirectVIVMap !
[ 80] Failed ES_Common API GetProcAddress: forward_glTexDirectTiledMapVIV !
[ 81] Failed GLES32 API GetProcAddress: glMultiDrawArraysEXT !
[ 82] Failed GLES32 API GetProcAddress: glMultiDrawElementsEXT !
[ 83] Failed GLES32 API GetProcAddress: glTexDirectVIV !
[ 84] Failed GLES32 API GetProcAddress: glTexDirectInvalidateVIV !
[ 85] Failed GLES32 API GetProcAddress: glTexDirectVIVMap !
[ 86] Failed GLES32 API GetProcAddress: glTexDirectTiledMapVIV !
[ 87] Failed GLES32 API GetProcAddress: glMultiDrawArraysIndirectEXT !
[ 88] Failed GLES32 API GetProcAddress: glMultiDrawElementsIndirectEXT !
[ 89] Failed GLES32 API GetProcAddress: glGetTexImage !
[ 90] Failed ES Common GLES2X API GetProcAddress: glMultiDrawArraysEXT !
ERROR: Could not create OpenGL context, root cause 'Could not create EGL context (call to eglCreateContext failed, reporting an error of EGL_B
AD_CONFIG)'
[2022-06-12 19:31:32.064] [645:000645] [error] ERROR: Could not create OpenGL context, root cause 'Could not create EGL context (call to eglCr
eateContext failed, reporting an error of EGL_BAD_CONFIG)'
I could find similar issue reported here as well when using chromium:
https://community.nxp.com/t5/i-MX-Processors/Chromium-EGL-issues-with-Wayland-and-Vivante/m-p/137503...
Anyone faced similar issues before and able to solve?
Please provide your suggestions to solve this EGL issue.
santhanakumar
Customer application requires X11 rather than wayland.
NXP SDK does not support pure X11 thus unable to get customer application working.
So closing this issue.
santhanakumar
Bio_TICFSL
You are working with an old version, this issue may be fixed, just try to port with a 5.15 kernel.
