Issues about DTS
Issues about DTS
1,264 次查看
tony_l_cai
Hi, all
     in DTS, we can see the follow:
fsl,pins = <
  MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x4001b8b1
  MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x4001b8b1
fsl,pins = <
  MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x1f8b0
fsl,pins = <
  MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x10
  MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15       0x10
  MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02        0x10
  MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03        0x10
  MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04        0x80000000
fsl,pins = <
  MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1
and I dont know how could I get the values which are back of the pins.Could you help me,3Q~
标签 (2)
1,104 次查看
igorpadykov
also good description
Definitive GPIO guide - Studio Kousagi Wiki
~igor
1,104 次查看
saurabh206
Senior Contributor III
Hi Tony
You can refer
kernel\Documentation\devicetree\bindings\pinctrl\fsl,imx-pinctrl.txt
