I am using imx8m mini EVK for my development purpose.
I am using Yocto project. I want to cross compile Mysql 5.7.28 using bitbake recipe for core-image-minimal.
I downloaded source code from https://downloads.mysql.com/archives/get/p/23/file/mysql-5.7.28.tar.gz
and trying to cross compile. But I am facing many issues.
Has anyone tried this?
Please find attached recipes for reference.
Hi gusarambula,
We are using mariadb recipe as a reference which is readily available.
I have attached the recipe in question. Can you please check?
Still I am facing many issues in cross compilation.
Abhijit
Hi Abhijit,
I'm also working on Mysql5.7.24-27. Need to integrate this with yocto. Please provide me the recipe, if exists or provide some input to create a recipe for this. I have seen these old recipe but not able get it properly.
Thanks & Regards,
Ramya
Hello Abhijit Thorat,
MySQL is not supported by our BSP. If you wish to integrate MySQL on your image you would need to either create a new recipe that builds and installs it, or you may cross compile outside Yocto and install it on your created image.
I couldn’t find MySQL recipes as part of the Yocto Project so you would need to create a recipe from scratch. This is not trivial but there is a lot of documentation online which may help. I would recommend starting with the Yocto Project Manual:
https://www.yoctoproject.org/docs/2.5/mega-manual/mega-manual.html#new-recipe-writing-a-new-recipe
If you would like to Cross Compile outside of Yocto you may extract the toolchain by following the instructions on the i.MX Yocto Project User’s Guide.
I hope this helps!
