Issue about "RALAT" for LPDDR2 in IMX6Q
shuaiwang
In the IMX6Q reference manual, the MMDC chapter has a register "MMDCx_MDMISC", as the RALAR described" in lpddr2 mode 2 extra cycles will be added internally in order to compensate tDQSCK delay". If this field set 5, that means total 5+2 cycle will be added in lpddr2 device?
gusarambula
Hello Shuai Wang,
Your assumption is correct, in the case of LPDDR2 mode two cycles would be added internally so if you select 5 in this field you would have 5+2 cycles added.
gusarambula
Hello Shuai Wang,
