Is there patch for iMX6Q DDR3 clock using 400MHz?
1,463 次查看
raymondwang
Senior Contributor I
For power consumption reduction,we need to try downgrade DDR3 clock to 400MHz(Currently it's 528MHz wihch is default option from FSL.
Any one got success story on 400MHz? Could you like to share experience with us on your patch?
标签 (3)
标记 (1)
1,161 次查看
raymondwang
Nobody degrade DDR3 to 400MHz to reduce peek power consumption?
1,161 次查看
SergioSolis
Are you using a specific board?, linux or android?
1,161 次查看
raymondwang
We are using new design board based on SabreSD. Because it's a handheld device, power consumption is key issue.
