Is there i.MX6 Platform SDK for imx6ul?
1,563件の閲覧回数
dongpv
Currently, We are developing our product base on imx6ul. with previous versions, I used i.MX6 Series Platform SDK version 1.1 to test our customize board using imx6dual and imx6dualLite but with this version, I can't find sdk and library for imx6ul. Could you please share me know where I can find this software?
Many Thanks,
Dong
3 返答(返信)
1,194件の閲覧回数
Hi Dong
unfortunately for i.MX6UL SDK was not released.
However since many modules are the same as for i.MX6DQ/SDL
in general it can be reused for it.
1,194件の閲覧回数
dongpv
Hi igor,
Thanks for your respond. I will try with your solution.
But I'm worry about address of register will be difference between imx6ul and  imx6DQ/SDL .
Do we need do some that changes before reused it?
As I know, In previous version, I can't reuse library from imx6DQ for imx6solo/dualLite then I have to library properly for imx6DSL.
Dong
1,194件の閲覧回数
Hi Dong
yes addresses should be changed for i.MX6UL.
