Is there anyone know how to correct touch event for DirectFB on MXS touchscreen with imx28?
ianhuang
hi,
I try to develop DirectFB app on imx28. But I encounter touch event issue that operate does not correctly.
I run ts_calibrate, it works fine.
And then export below before execute df_window.
export TSLIB_CONSOLEDEVICE=none
export TSLIB_FBDEVICE=/dev/fb0
export TSLIB_TSDEVICE=/dev/input/event1
export TSLIB_CONFFILE=/usr/etc/ts.conf
export TSLIB_PLUGINDIR=/usr/lib/ts
But touch event seems like unworkable.
Thank you.
Jeff_ng
yes,
/* Note: imx28 modifications to make DirectFB work with tslib:
     * 1. modify ~/ltib/dist/lfs-5.1/DirectFB/DirectFB.spec, remove linuxinput from $TSOPTS
     * 2. mknod /dev/input/tslib0 c 13 65
     * 3. export TSLIB_TSDEVICE=/dev/input/tslib0
     * 4. ./ltib -c
     * 5. note I use ts_read in non-blocking mode
#define TS_READ_BLOCK   1
      if( (tsdevice = getenv("TSLIB_TSDEVICE")) != NULL ) {
          ts = ts_open(tsdevice,TS_READ_BLOCK);
