Is there any restrict to input a interrupt after i.MX6 sleeps?
711 次查看
satoshishimoda
Senior Contributor I
Hi all,
I'm evaluating a i.MX6D board.
Then, i.MX6D did not wake-up from low power mode if a wake-up interrupt is input to i.MX6D immediately after i.MX6D changes PMIC_STBY_REQ signal from 0b to 1b.
So I guess, there is a timing restriction to input a wake-up interrupt.
(e.g. wake-up interrupt should be input to i.MX6 after xx [sec] or over from PMIC_STBY_REB changes 0b to 1b.)
Is my guess correct?
If correct, could you let me know how log time is needed from PMIC_STBY_REQ 0b -> 1b?
Satoshi Shimoda
标签 (4)
标记 (2)
586 次查看
AnsonHuang
Hi, Satoshi
     As far as I know, there is no restriction, how do you test it? I have ever tested such case before, it can wakeup system. Can you let me know the test steps of yours?
