Is there any freescale chip containing ethernet PHY and ethernet switch?
981 次查看
dolevojay
Could anyone tell me if there is a Freescale chip where there is built-in ethernet phy and switch?
thanks.
849 次查看
ZhangJennie
i suggest you use Solution Advisor  which is very easy to choose the correct device for your requirement.
http://freescale.transim.com/solutionadvisor/SolutionAdvisor.aspx?t=features
