Is there any calculation tool of DRAM bus length for i.MX7ULP ?
1,036 次查看
ko-hey
Senior Contributor II
Hi all,
I'll building a custom board with i.MX7ULP.
I understand that the wiring of each DDR signal line (the wiring from the CPU BGA pad to the DDR BGA pad) must be of equal length.
Is there any information about the wiring length inside the CPU (the wiring length from the DDR controller inside the CPU to the BGA PAD) ?
Or is there any calculation tool of DRAM bus length for i.MX7ULP ?
I found following check sheet but it's for i.MX6.
https://community.nxp.com/docs/DOC-93819
Ko-hey
985 次查看
Yuri
   It is recommended to use section 3.4.1 (DDR routing rules) of the
Hardware Development Guide for the i.MX 7ULP.
https://www.nxp.com/webapp/Download?colCode=IMX7ULPHDG
It is quite enough for practical purposes.
Yuri.
