Is there any Qt 5 gstreamer backend for iMX6 ?
3,525 次查看
charleshuang
Senior Contributor II
I can find Qt4.7.4 gstreamer backend support for iMX5 (link here).
Does Freescale have any plan to support Qt5 gstreamer backend for iMX6?
8 回复数
2,247 次查看
YixingKong
Senior Contributor IV
Charles
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
2,247 次查看
YixingKong
Charles
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
2,247 次查看
OtavioSalvador
Yes, Qt 5.3.0 has support for it.
In meta-fsl-arm the daisy branch has the backport of it for 5.2.1 and in master it is already using 5.3.0. You can use it with the Qt Multimedia Framework.
2,247 次查看
jack_mao
      FSL will not support the QT porting issue, to use gstreamer in QT, customer should do the related work by themseleves.
Jack
2,247 次查看
YixingKong
jackmao, would you like to answer this question?
Yixing
2,247 次查看
jim_lin
to be more specific, what Charles(Advantech) need, is to have hardware decode support in QT5.0.
So far they can have QT5.0 running on their MX6 platform based on Linux 4.0.0 and play video, but video playback is not smooth, seems it's software-decoded.(not by VPU in MX6)
Hello Charles,
please correct me if anything wrong with my statement above.
Jim Lin.
2,247 次查看
EricNelson
FWIW, Digia is supporting this directly.
See 1:00 in the video on this page:
  http://blog.qt.digia.com/blog/2014/05/13/news-from-the-qt-webengine-team/
2,247 次查看
Wlodek_D_
Thank you for your post, however please consider moving it to the right community place (e.g. i.MX Community ) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
