Hello all.
I am testing the sleep modes of IMX6QSABRESD. I can wake up the processor by using UART interrupt as it is mentioned in the Linux Reference Manual.
However, is there a way to wake up IMX6Q processor by using ethernet interrupt?
Thank you in advance.
Solved! Go to Solution.
Hi Giray
please check patch on
Wake on lan in mx6 sabresd board
Hi Giray
