Is there a counter for SDIO Errors in imxull-usdhc/sdio linux module?
579 次查看
JohnKlug
Senior Contributor I
For instance /proc/net/dev will list networking errors/re-transmissions.
From what I understand SDIO has checksums and re-transmission capability.  Are there any counters for this in the Linux driver?
I was just wondering if I adjust drive strength, clock speed, etc. if there was anything in the driver to see if I was on the right track.
1 回复
567 次查看
Bio_TICFSL
There is no counters in MX code, but you can put on it to see any of the component is working.
