Is there a QT app to display network strength?
已解决
跳至解决方案
2,047 次查看
sujay1
Contributor V
I am using yocto BSP with qt5.9.
I need an app that can display the network strength.
In Android we get this on the top left denoted by 4 lines (number of lines depend on signal strength).
is there any app we can run for the similar effect on yocto?
标记 (3)
1 解答
1,915 次查看
karangajjar
Senior Contributor II
Hi Sujay S,
There is no particular example for showing the signal strength in qt5 imx image. However you can have a look at examples under qt5/examples/network
Also, you can build one simple application to check out the signal strength and cross compile for imx platform.
Please follow below document for more information:
Enable QT developement for i.MX6UL
Building QT for i.MX6
Karan Gajjar
在原帖中查看解决方案
2 回复数
1,915 次查看
b36401
We have no such utility.
However you can write simple QT application to run iperf (commandline network benchmark).
1,916 次查看
karangajjar
Hi Sujay S,
Karan Gajjar
