Is it securely to print out CAAM keys to console?
1,736 次查看
dimtref
Hi, NXP
I am developing an application that runs on an imx6ul based industrial embedded computer. Linux has been built with using yocto.
Is it securely to print out to console all keys by CAAM on boot up?
platform caam_sm: blkkey_ex: 8 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 3c a8 41 75 ce eb eb 36
platform caam_sm: [0008] 0f e5 59 ba 35 ef 33 3a
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 35 a4 be 55 7b e7 fd 21
platform caam_sm: [0008] 2b ca 03 b8 f7 95 05 1e
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
... and so on
If not, how can I turn out this?
标记 (2)
1,579 次查看
Yuri
  the mentioned log relates to CAAM tests.
Some details may be found in the following discussion.
How to decrypt and use a black key?
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
