Is it possible to boot from USB with the RT1172?
819 次查看
LuisC
How can you configure the RT1172 to boot from USB (if possible)?
803 次查看
jingpan
Hi @LuisC ,
Set the chip to serial download mode. It can support download code to SRAM and run via USB/UART. SDPhost.exe is used on computer to connect and download.
Jing
