Is it OK to use DDR3 mixed configuration both on-board and SODIMM for i.MX6?
已解决
跳至解决方案
1,214 次查看
t-iishii
Hi community,
My customer plan to use DDR3 DIMM module as a extended memory for i.MX6 products.
Of the total 4 GByte of memory, 2 GByte is prepared on-board and the rest are prepared by SO-DIMM.
Does anyone have an use case with such a configuration?
Ishii.
标签 (1)
1 解答
1,111 次查看
Hi Ishii
I do not know such designs but seems it is possible following
layout recommendations given in sect.3.5.5 4-Gigabyte recommendations
i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
在原帖中查看解决方案
2 回复数
1,112 次查看
Hi Ishii
1,111 次查看
t-iishii
Hello igor
Thank you for your quick response.
If it use 4GByte recommendation design, it can use different timing parameter for each Chip Select?
Ishii.
