Is i.MX7S CCM_CLK2 an output?
已解决
跳至解决方案
1,384 次查看
tmeyer
I need some clarification on the CCM_CLK2 function.
In the manual IMX7SRM (Rev. 0.1) Table 5-10 defines CCM_CLK2 as an output. However, in IMX7SCEC (Rev 3.0) Table 3. says that is in a output.
I am currently under the assumption that it is a input only, however if it may act as a output, can you point me to the documentation (or linux-fscl source) that handles this.
Thanks.
Tim Meyer
标签 (2)
标记 (1)
1 解答
1,233 次查看
tmeyer
NXP confirmed that CCM_CLK2 pin is an input only.
在原帖中查看解决方案
1 回复
1,234 次查看
tmeyer
