Hi community.
The i.MX6solo has the following description on the product page, indicating that it is AEC-Q100 compliant.
-Package and Temperture ...Automotive (-40C to +125C), AEC-Q100, up to 800 MHz GHz
However, there is no mention of AEC-Q100 on the i.MX6UL product page.
Does this mean that i.MX6UL is not AEC-Q100 compliant?
Best regards.
Solved! Go to Solution.
It is strange that it is not mentioned on web page but, you can be sure that i.MX6UL is AEC-Q100 compliant.
Here a section of AEC-Q100G Tier Qual Results.
Best regards.
Hello, I hope you are doing well.
Yes,i.MX6UL automotive grade supports the AEC-Q100 grade 3.
Best Regards.
Hi JorgeCas.
Thank you for your reply.
Is there any documentation stating that i.MX6UL supports AEC-Q100?
ex.)Datasheet and other
I have checked several documents and web pages, but there is no mention of it.
Best Regards.
It is an internal document. i.MX6SX Auto Qualification report can be obtained only through NDA.
Best regards.
Hi JorgeCas.
I don't want a detailed report, I just want to check the AEC-Q100 indication on the website or published documents to provide information to customers.
And although your reply says i.MX6SX, what is needed is the information for i.MX6UL.
For example
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
i.MX6solo webpage has an AEC-Q100 indication.
https://www.nxp.jp/products/processors-and-microcontrollers/arm-processors/i-mx-applications-process...
i.MX6soloX webpage also shows AEC-Q100.
However, there is no mention of AEC-Q100 support on the i.MX6UL webpage.
I would like to check whether the i.MX6UL supports AEC-Q100 but it is not listed or whether it is not supported.
Best regards.
