Is commercial grade, industrial grade, consumer grade CPU exist at the same time?
sunlihong
As the title described, is commercial grade, industrial grade, consumer grade CPU exist at the same time?
As shown in the above picture, in the "Temperature" part, there is Consumer category and Industrial Category. Why there is no "commercial" category. Does "commercial" category exist?
joanxie
where did you get information that imx has  commercial grade? could you share with me? I only heard that imx series has consumer, industrial and automotive grade
sunlihong
sunlihong
Have you ever seen this picture(there is Commercial grade, Extended commercial grade, it's cut from NXP documents, I will try to find the source document, since they are not cut by me, maybe it will take a relatively long time to get the source document?
joanxie
commercial grade is the consumer grade, the picture you post is from imx6dl data sheet, you can download it to check, the "5" in the part number means commercial/consumer grade, I attach the data sheet
sunlihong
If commercial grade is consumer grade, why using two different words? it easily creates misunderstanding.
