Is IMX8M Plus using WDQS?
haryanl
Hi all,
I am confirming whether the IMX8M Plus has the WDQS function enabled?
I checked the RPA excel file, but I don't understand clearly.
Can you confirm this for me?
1. If it is enabled then, use Mode 1 or Mode 2 as shown below (From DDR datasheet)
2. In the RPA file, where can Enable/Disable be confirmed?
pengyong_zhang
Hi, @haryanl
on i.MX8MP, we enable the WDQSEXTENSION feature of the DDR PHY whose description is as follows:
When set, DQS_T and DQS_C will be driven differentially to 0 and 1, respectively,
before and after a write burst, except during a memory read transaction.
From that I understand that DQS should be driven low at all times except a memory read transaction.
Here is measured the behavior of the system on 8MP EVK when WDQSEXTENSION is enabled and disabled:
pengyong_zhang
Hi, @haryanl
Yes! You are right!
B.R
pengyong_zhang
Hi, @haryanl
haryanl
Hi @pengyong_zhang ,
Thank for your reply.
in the RPA file, is it confirmed here?
By default it is set to enabled
Because WDQS_Extension is used, is it correct that I understand that corresponds to DDR Mode 2: WDQS_on / WDQS_off definition based control?
%3CLINGO-SUB%20id%3D%22lingo-sub-1877743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIs%20IMX8M%20Plus%20using%20WDQS%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3EI%20am%20confirming%20whether%20the%20IMX8M%20Plus%20has%20the%20WDQS%20function%20enabled%3F%3CBR%20%2F%3EI%20checked%20the%20RPA%20excel%20file%2C%20but%20I%20don't%20understand%20clearly.%3CBR%20%2F%3ECan%20you%20confirm%20this%20for%20me%3F%3CBR%20%2F%3E1.%20If%20it%20is%20enabled%20then%2C%20use%20Mode%201%20or%20Mode%202%20as%20shown%20below%20(From%20DDR%20datasheet)%3CBR%20%2F%3E2.%20In%20the%20RPA%20file%2C%20where%20can%20Enable%2FDisable%20be%20confirmed%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22haryanl_0-1717034852012.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22haryanl_0-1717034852012.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281621i8F0882E63D1C1089%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22haryanl_0-1717034852012.png%22%20alt%3D%22haryanl_0-1717034852012.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThanks%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1877743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Is%20IMX8M%20Plus%20using%20WDQS%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F163294%22%20target%3D%22_blank%22%3E%40haryanl%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes!%20You%20are%20right!%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Is%20IMX8M%20Plus%20using%20WDQS%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20for%20your%20reply.%3C%2FP%3E%3CP%3Ein%20the%20RPA%20file%2C%20is%20it%20confirmed%20here%3F%3CBR%20%2F%3EBy%20default%20it%20is%20set%20to%20enabled%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22haryanl_0-1717051794890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22haryanl_0-1717051794890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281688i2A47ADFFBF844695%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22haryanl_0-1717051794890.png%22%20alt%3D%22haryanl_0-1717051794890.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBecause%20WDQS_Extension%20is%20used%2C%20is%20it%20correct%20that%20I%20understand%20that%20corresponds%20to%20DDR%20Mode%202%3A%20WDQS_on%20%2F%20WDQS_off%20definition%20based%20control%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Is%20IMX8M%20Plus%20using%20WDQS%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F163294%22%20target%3D%22_blank%22%3E%40haryanl%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eon%20i.MX8MP%2C%20we%20enable%20the%20WDQSEXTENSION%20feature%20of%20the%20DDR%20PHY%20whose%20description%20is%20as%20follows%3A%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EWhen%20set%2C%20DQS_T%20and%20DQS_C%20will%20be%20driven%20differentially%20to%200%20and%201%2C%20respectively%2C%3CBR%20%2F%3Ebefore%20and%20after%20a%20write%20burst%2C%20except%20during%20a%20memory%20read%20transaction.%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EFrom%20that%20I%20understand%20that%20DQS%20should%20be%20driven%20low%20at%20all%20times%20except%20a%20memory%20read%20transaction.%3C%2FP%3E%0A%3CP%3EHere%20is%20measured%20the%20behavior%20of%20the%20system%20on%208MP%20EVK%20when%26nbsp%3BWDQSEXTENSION%20is%20enabled%20and%20disabled%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_0-1717050378634.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1717050378634.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F281676iF4054E5D36E672EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_0-1717050378634.jpeg%22%20alt%3D%22pengyong_zhang_0-1717050378634.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
