Hello all,
While reading the Display data sheet I came to know that it can be interface using 8/9/16/18-bit 6800-series/8080-series Parallel Interface.
But I didn't find any reference to this interface in the i.MX6 documentation.
So, I just want to know whether this interface is available on the i.MX6 ?
SR
Solved! Go to Solution.
Hi shree97
asynchronous displays (smart lcds) are not supported by IPU of i.MX6DQ/SDL processors.
Is it possible to implement this System-80 interface using GPIO pins?
If yes, kindly guide me for it.
Thanks & Regards,
SR
Hi shree97
Thanks igorpadykov for your reply.
