Internal LDO output spec in i.MX6UL/ULL
ko-hey
Senior Contributor II
Hi all
I have a question about accuracy of internal LDOs output in i.MX6UL/ULL.
Could you tell me the spec of internal LDOs output min, typ and max ?
Ko-hey
Labels (2)
Tags (2)
art
The accuracy of the i.MX6UL/ULL internal LDOs is within one regulation step, i.e. voltage target regulation point +/- 25mV, if not overloaded.
Artur
ko-hey
Hi art
Do you have Max and min spec for LDO_SNVS ?
Ko-hey
ko-hey
Hi Artur Petukhov
Could you follow the question ?
Ko-hey
