Hi @Chavira ,
Thank you for your support.
Hier is how the fec device tree in Linux described:
&fec1 {
fsl,magic-packet;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_fec1_gpio>,
<&pinctrl_fec1>;
phy-mode = "rgmii-id";
phy-handle = <ðphy0>;
phy-supply = <®_3v3_eth0>;
status = "okay";
mdio {
#address-cells = <1>;
#size-cells = <0>;
ethphy0: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0>;
interrupt-parent = <&gpio5>;
interrupts = <2 IRQ_TYPE_LEVEL_LOW>;
micrel,led-mode=<1>;
reg_3v3_eth0: regulator-ethphy {
compatible = "regulator-fixed";
off-on-delay=<500000>;
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-name = "3v3_eth0";
startup-delay-us = <200000>;
pinctrl_fec1_gpio: fec1gpiogrp {
fsl,pins = <
/* PHY interrupt */
MX8MN_IOMUXC_SAI3_MCLK_GPIO5_IO2 0x19
pinctrl_fec1: fec1grp {
fsl,pins = <
MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3
MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3
MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f
MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f
MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f
MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f
MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91
MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91
MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91
MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91
MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f
MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91
MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91
MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f
