Hi Team,
Greetings of the Day!!
dtbo.img file is working fine!!!!!!!.
card also detected and listed out in asound
phyboard_pollux:/#cat /proc/asound/cards
0 [wm8960audiosoun]: wm8960-audio-so - wm8960-audio-sound
wm8960-audio-sound
1 [audiohdmi]: audio-hdmi - audio-hdmi
audio-hdmi
phyboard_pollux:/sdcard/Download #
1. in command prompt using Tinyplay command we verified the module is working. default wm8960 module is taking and audio also playing.
2. we played the alarm default songs and we can audible the songs in wm8960 module.
verified in logcat it using card 0.
05-10 11:49:47.396 361 3007 D audio_hw_primary: start_output_stream: pcm_open: out->device: 2, card: 0, pcm_device_id: 0, rate: 48000, channel: 2, f9
3. suppose we played the audio through any media player application/app, we can't hear any audio.
but in logcat it showing card 1.
05-10 09:44:07.112 364 1721 D audio_hw_primary: start_output_stream: pcm_open: out->device: 1024, card: 1, pcm_device_id: 0, rate: 48000, channel: 28
3.1 what changes required to play the audio through media player app?
3.2 audio_policy_configuration.xml any configuration changes are required?
some configuration added in this but its not happens what we expected.
Sachin
