Integrate a new hardware into Android (3) -blog archive
1,030件の閲覧回数
AlanZhang
Now, let's come to the implementation of LED Service Entity that is resided in Framework layer. For legacy architecture, the LED Service Entity is quite straightforward. The LED Service Entity code is resided in frameworks/base/service/java/com/mokoid/server/LedService.java.
Application Test Code
The test code is resided in apps/LedClient/src/com/mokoid/LedClient/LedClient.java as following:
  1. package com.mokoid.LedClient;
  2. import com.mokoid.server.LedService;  // Import LedService in FrameWork layer
  3. import android.app.Activity;
  4. import android.os.Bundle;
  5. import android.widget.TextView;
  6.
  7. public class LedClient extends Activity {
  8.     @Override
  9.     public void onCreate(Bundle savedInstanceState) {
  10.         super.onCreate(savedInstanceState);
  11.         // Call an API on the library.
  12.     LedService ls = new LedService();  // Instantiate LedService
  13.     ls.setOn(1);                       // via public methods to control low level hardware
  14.     ls.setOff(2);
  15.
  16.         TextView tv = new TextView(this);
  17.         tv.setText("LED 1 is on. LED 2 is off.");
  18.         setContentView(tv);
  19.     }
  20. }
タグ(1)
911件の閲覧回数
daiane_angolini
Great, thanks for sharing.
