Dear Sir,
Our customer want to use innolux,at043tn24 panel on i.MX6ULL platform.
We check RM support below four mode
• MPU Interface
• VSYNC Interface
• DOTCLK Interface
• ITU-R BT.656 Digital Video Interface (DVI)
innolux,at043tn24 (attached file) don't have V/H Sync pads and it used DE pad (mode) to control.
We are not sure i.MX6ULL could support it.
Could you help confirm it?
Hi andychien
yes it can be supported in DOTCLK Mode as described in Figure 34-13 (signal "ENABLE")
DOTCLK protocol with programmable parameters and Table 34-5. Pin use in DOTCLK Mode
i.MX 6ULL Applications Processor Reference Manual
