Inquiry i.MX6 BSDL question
andychien
Dear Sir,
Our customer used i.MX6 Solo and want  to know Boundary Scan test can cover i.mx6 IC  how many pins. (how many pins can test ? )
I checked some documents and can't find it.
Could you help check and provide it?
Thanks a lot,
igorpadykov
Hi Andy
please look at bsdl file and check number of controlled pins
IMX6_DL_S_BSDL
IMX6DQ6SDLHDG Chapter 9 Understanding the IBIS Model
andychien
Dear Sir,
I and customer already check you provide documents of link.
We are not sure correct pin numbers for BSDL cover test.
Please help ask or check, then provide it.
Thanks a lot,
PS. BSDL is Chapter 11 Using BSDL for Board-level Testing on  IMX6DQ6SDLHDG
