Dear Sir,
Our Customer setting VDDPU turned off turing startup on i.MX6D , Linux OS.
customer suspect that it will be turned on unless there is an application using the VPU want to use imx6q-cpufreq.c if the PU regulator is enabled.
Could you help check in imx6q-cpufreq.c if the PU regulator is enabled?
Hi Andy
please check vpu driver mxc_vpu.c in linux/drivers/mxc/vpu, it uses regulator_enable(vpu_regulator)
and reg_pu: regulator-vddpu in imx6qdl.dtsi
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/boot/dts/imx6qdl.dtsi?id=r...
regulator_set_voltage_time(pu_reg..,regulator_set_voltage_time(soc_reg.. using array
imx6_soc_volt[] = PU_SOC_VOLTAGE_NORMAL
