Hello Markus,
About ESD protection:
(1) Considering CPU pin's rating, at first
About rating, see datasheet of i.MX6,please! all pins has been listed in it.
(2)Selecting ESD parts according to Pin's rating.
There are 2 the most important parameters we must focus on :
-----Reverse stand-off voltage : At the voltage, ESD doesn't work.
-----Reverse broken down voltage :After this voltage is exceeded, the diode is rapidly reversed and enters the conduction state.
(3)About Clamping Voltage
:After this voltage is exceeded, the diode will be damaged. The parameter is only related to ESD part, running environment of hardware and max surge voltage, no relations with CPU pin.
(Weidong)
