1. Could you tell me the register address of pcie Gen-1 and Gen-2?
2. If I want to modify pcie Gen-1 and Gen-2 register parameter values, how do I modify in the program file?
Thank you.
Alex Cheng
Hi charles,
please check AN4784 and link below
How to setup i.MX6Dual/Quad and i.MX6Solo/DualLite Linux software for PCIe compliance Test?
chip
Hi Chipexpert,
If I follow your compliance test method, do I need to consider the setting value of PCIe Gen-1 and Gen-2 register about SI test?
If the answer is no, I want to modify PCIe Gen-1 and Gen-2 register parameter values. How do I modify in the program file?
Thanks.
Hi charles,
please look at AN4784 it shows
settings for both Gen1 and Gen2.
chip
Hi chip,
I know. Thank you for your reply.
Charles
