In SAF775x(Dirana 3) How the Audio Samples routed ?
tobin_tomy
How the audio samples are routed from ADC to DSP libraries . ? I mean how the Audio Inputs will be given to DSP? Is it through DMA buffers using Interrupts? Can I know the routing or can any provide supporting documents for the same ?
