In Lite5200, Linux-3.18.9 fails to assign the Major number to Nor Flash(with uboot-1.2.0)
1,078件の閲覧回数
anilkdevagiri
Kernel command line:
VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Rebooting in 180 seconds..
853件の閲覧回数
anilkdevagiri
It is solved by adding the "chosen" node in device tree.
All the best.
854件の閲覧回数
anilkdevagiri
All the best.
