Imx93 debugging ov5640 is not satisfactory.
741 次查看
xiang_1001
Use the command to preview, see the attachment for the effect and device tree.
The preview effect is not ideal. Can it be improved?
722 次查看
joanxie
did you try the lower resolution? is it better, how about tying the command "gst-launch-1.0 v4l2src ! video/x-raw,width=1920,height=1080 ! waylandsink"?
716 次查看
xiang_1001
Used this command:gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw,width=1920,height=1080" ! queue ! waylandsink
The effect is the same.Reduce the resolution, the effect will be better.
679 次查看
joanxie
you can try to use v4l2 to capture one picture to check if the performance, if this is good, it seems this is related to your display side, this isn't imx93 issue, imx93 HW can support 1080p@30
