After the Android boot is complete, I want to use the apk to open the camera. Instead of using evs_app.
How to modify the configuration to add camera3 Hal?
I tried to modify it but it was always a mess.
Solved! Go to Solution.
I solved this problem myself, and now share it.
Still no results, is there a patch file?
